jsawyers avatar image
jsawyers asked
Rebulk voltage offset not working
Rebulk voltage offset set to 0.1v as per battery manufacturers specs. Float voltage at 13.02v. Battery voltage drops below 12.7v, however charge controller remains in float. When disabling and enabling charge controllers, they turn back on in the bulk state.
Is this an issue that is being worked on, or is there a solution I’m missing?
MPPT Controllers
