abdallah-salamah avatar image
abdallah-salamah asked
Quattro overload alarm
we have a single phase backup system with two 10 KVA Quattro’s which has been operated since 2015.
Suddenly when the grid shut down and come back the master has the error as shown in the attached video.
Then at the next time when the grid shut down, there is no power from the inverter but when restarting the inverters the system goes fine and so on when the grid come back.
I tried to make it as the slave, but it shows an overload alarm and has no power.
I updated all the units to the latest version, but no change.
The error appear even no load connected.
quattro 10kva
@Abdallah Salamah
Most times with a master slave config it is a wiring issue, often on the ac side of things, same lengths etc need to be adhered to.
If you have a gx the error code that comes up is helpful in diagnosing the issue.
You may also need to get your units cleaned out. The dust there can also cause issues.
abdallah-salamah avatar image abdallah-salamah Alexandra ♦ commented ·
Thank you, i divided the system and make it operate alone and the problem still done.
Unfortunately, there is no gx.
Alexandra answered ·
@Abdallah Salamah
You will have to take it for repair. There is an internal component damaged, will need to be replaced.
