My inspector want to see the high current dc input leads in conduit. Is there a way to do that with the multiplus or quattro?
https://uk.rs-online.com/web/c/cables-wires/cable-conduit-trunking-routing/conduit/
Not sure exactly what your inspector may be looking for. Or of the suggestion will meet regulation your side.
We use the split flexible stuff down to trunking and run it like that, or flexible the whole way depending on the install.
The Multi/Quatro requires the lower panel to slide down and away for maintenance so rigid conduit to the bottom of the panel wouldn't be possible. It would need to be flexible conduit and even that would be a royal pain. Not sure if the MP II line has this same requirement.
I would enclose the bottom of the inverter in a raceway that covers all wiring. Of course, you'd need to provide a ventilation path through the raceway to the bottom of the Multi/Quatro.
29 People are following this question.
