bobbi787 avatar image
bobbi787 asked
Multiplus 3000 AC-OUT-2 grounding?
Hi all - I'm preparing to wire the Multiplus 3k and want to use the auxiliary AC-out-2. The AC-out-2 includes Line and Neutral connections but no ground, unlike the neighboring AC-out-1. Where do I wire the ground for AC-out-2? Can it go to the same ground port as AC-out-1?
Multiplus-II
shaneyake avatar image
shaneyake answered ·
Yes, you can use the same grounding as AC-OUT 1, typically you have a grounding bar in your panel that you can use for everything. The AC-IN and AC-OUT grounds are linked internally as well.
