Need help. I have a Renogy 200w suitcase solar panel, Victron smartsolar 75/15 and 2 Trojan t105 6v connected as 12v. I am showing 0 watts and 0 current. Checked all connections twice.
I hook up the battery first then I hook up pv, that’s when the controller starts up. Is the controller supposed to turn on when I hook up the battery?
So I checked all connections, fuses and wiring and all is good. However, I notice that I can completely disconnect from the batteries (2 6v), and the battery readings shown above don’t change or even waiver for that matter. Seems odd to me?
Hi there I would suggest maybe power down the mppt for a while to allow the internal capacitors to discharge, when connecting it as mentioned battery first then pv and disconnection has to be the reverse of it. If the mppt powers down for 30mins should be enough time I would try that if not you have a power source coming another direction to power it I would try a full disconnect and reset and check with a multimeter you are getting power at all ends of the circuits from solar pv array also thanks david
There are many questions about that in the community.
Did you also checked the fuse at the MPPT?
What happens if you disconnect PV?
29 People are following this question.
