davebda avatar image
davebda asked
Multiplus not working
My system was running correctly when I turned it off to add a solar charger. Got the charger mounted and wired but not activated yet. Turned the multiplus back on and it does not come on. No lights, no relay clicking. I meter 120 at the input but no joy. Any suggestions would be appreciated.
rickp avatar image rickp commented ·
I would return the wiring as it was prior to the SCC, and see if it works. If it does, recheck installation of the SCC and wire just the controller in with no PV, etc, until you find the fault.
Jean-Pierre Krickx avatar image
Jean-Pierre Krickx answered ·
I also have this problem, did you find a solution for it?
regards
