mivazo avatar image
mivazo asked
Charging with two Blue Smart IP67 Charger 25A in parallel?
Is it possible to charge a 200Ah LiFePo4 battery bank with two Blue Smart IP67 Charger 25A in parallel to gain faster charging time when mains power is available?
And will it be a problem if a MPPT 100/50 is charging at the same time.
Thanks in advance.
battery charging
Paul B avatar image
Paul B answered ·
No Problem Charge away, but check with your battery manufacturer to make sure you do not exceed there maximum charge rate (Amps)
all of them will reduce there charge rate when required.
mivazo avatar image mivazo commented ·
Thank you. The max charge rate is fine.
