kurts avatar image
kurts asked
Better connect a Generator as Grid replacement or internally to the Multiplus?
In Winter I want to be also autark and use a Honda i10 to charge and support my batteries when they get low. I could connect the Generator simply at the mains socket. But there seems a methog to connect directly top the multiplus. I would not always have it with me so need to be a plug-.able connection.
Which method is better?
Generator
You have invented a couple of new words..
autark and methog , Perhaps you could please explain?
What is your Multi??
mrhappy avatar image
mrhappy answered ·
Perhaps these are suitable, the CEE 16A connectors. Mount the male inlet by the multiplus connected to AC-in, have your grid power coming to a female connector which you can connect and make a cable with a female connector for the generator.
I didn't get from your post if you had grid connection or not, but if you do, you always want to disconnect from the grid if you connect a generator.
