tuner79 avatar image
tuner79 asked
Smartsolar charger mppt 100/30 Clicking noise
I had this unit installed on my boat with 2 ridged panels. It makes a loud clicking almost relay noise when I’m not hooked up to shore power in the mornings under low sun conditions. Once the sun hits the panels a lot it goes away. It’s loud and wakes us up. Happens in the evenings as well. When it charges everything worked fine. Any help would be greatly appreciated!! Picture attached is when it happens. fd1bbde9-a872-497f-b081-a760d0004ed8.png
MPPT Controllers
Paul B avatar image Paul B commented ·
what is the OC voltage of the panels and have you got them connected in series or parallel
you should see the Open circuit voltage on the panels lable
