muddy1 avatar image
muddy1 asked
Multiplus II - DC current is wrong.
I have a Multiplus II 48v 5KVA. When running but with the output isolated, Venus reports 53.53v and -0.7a, giving 37.47W standby power.
Clearly greater than the specified 21w standby power.
The reported current is incorrect, a clip on meter gives 397mA which would give the correct 21W standby power. It is disappointing to find such a large discrepancy on a quality product.
This causes problems with negative DC currents which have been discussed on numerous posts.
Is there any way to zero the current meter in this unit ?
Multiplus-II
wkirby avatar image
wkirby answered ·
Remember that the ADC in this device is expected to measure over 180A (9KW peak). It's probably a 10bit ADC, so it has a resolution of about 175mA. All ADC's, despite filtering and smoothing have an ammount of jitter and an error of 1 or 2 bits on a scale of 0 to 1024 is quite acceptable.
You are measuring right down in the noise floor and observing an error of less than 0.1% over the entire range up to 180A. This device which is primarily designed to convert vast ammounts of power (which inherently generates a lot of electrical noise) isn't doing too bad at measuring current.
A unit of this size is normally measuring tens of Amps so the resolution of a few hudred milliamps is in the noise and perfectly reasonable for its intended use.
Think of it like a car speedometer which goes from 0 to 200Km/h. It can't really measure a speed of 0.1Km/h and increments of 0.1Km/h are indiscernable and not required either.
The measurement electronic inside the MultiPlus is not designed to be super accurate.
There is not much you can do about it.
lex2k0 avatar image
lex2k0 answered ·
Thanks a lot for that answer, that the Multiplus can't be that accurate in low usage situation. However, is there maybe a chance to somehow use an external DC sensor to make it more accurate? Maybe to use a single Shunt somehow for the Multiplus? In my situation it is a Quattro II.
