Good Day,
Is it possible to use a common ground, to connect the 2 arrays PV input for the charge regulator SmartSolar MPPT RS - 450/100?
Because the regulator is far from the panels, and I have only 3 wires from the connection box.
Thanks
Good Day,
Thanks
This would not work:
PV+ and PV- need to be isolated from ground.
Each of the PV trackers need to be isolated from one another, so connecting to ground or sharing PV- would not work.
Much better to run four wires 2x PV+ and 2x PV- and then a ground wire from MPPT chassis to PV frames depending upon your local regulations.
27 People are following this question.
