jolilo avatar image
jolilo asked
(not quite resolved) current limit and block FAN HELP
the fan of my multiplus II is blocked at night during its shutdown and in the morning I have to restart it by hand.
I ordered a new fan, in the meantime can we force the fan to run permanently
Hello everyone
I need some information:
my system: multiplus II GX 3000VA 48
: MPPT 150-60
:COUNTER
ESS, DVCC charging current limit 60A
lifepo4 200Ah 16x 3.2v
voltage absorption 56v
Float voltage 54v
with a -1000w network, 1600W MPPT power
the charging current peaks at 40A?
which parameter is blocking?
Hello ,
I was able to have the SMA party AC recognized
The output power of the multiplus is limited to 1000w why?
the battery should provide the missing power
sorry for my bad english google and my friend and i'm french
How to control the operation of the cooling fans of the multiplus
I find the multiplus II very hot and I don't hear the noise of the fans running
Good evening, I opened the lid of multiplus II GX, the fan was blocked, which explains the current limitation in charge and discharge to limit the temperature of the devices
Multiplus-II
@jolilo
Something does not add up there.
If you are only producing 1572W according to the GX how is it charging at 2200W but you are also exporting 1000W?
How are you monitoring the battery SOC, or is it a managed battery with communication to the gx?
