Christopher A. Lindner avatar image
Christopher A. Lindner asked
Multiplus not connecting to Onans HDKBB-6880 Generator
I have a Multiplus 12 | 3000 | 120 - 50 | 230/240V , I recently purchased a Onans HDKBB-6880 diesel generator which i have just installed . the problem i am having is the Multiplus won't connect to the Generator unless I put an external load on the generator 1st.
The generator is producing 232 volts but until I introduce a load the output of the generator the Frequency on the multi meter shows as over 100hz, once the load is introduced the frequency stabilizes at 50hz.
Can the Multiplus be set to create a load on the Generator prior to full connection.
Thanks Chris
