shaper avatar image
shaper asked
MultiPlus 12/1600/70 accidentally overload
Hi everyone, new installed Multiplus 12/1600/70 was accidentally overloaded with the high capacity appliance (like kettle 1800-2000 watt). And now batteries indicator always shows "low battery" and inverter doesn't start, charger shows "absorption" but seems not charging (it is "ON" two days already with the main).
Could anybody can give some advise please, it would be very worthy.
Thank you
JohnC avatar image
JohnC answered ·
Hi @shaper
Those symptoms suggest a wiring failure between the batts, possibly a blown fuse or isolator contacts. Check all that thorougly first, both + and - wires.
shaper avatar image
shaper answered ·
Thank you a lot, I will check it thoroughly.
