pau-hana avatar image
pau-hana asked
AC input to Quattro from generator
Good evening. I tested my generator output prior to connecting to the Quattro AC1 input. Generator output is 120v 60hz. Some questions:
- checking ground with either hot or neutral resulted in a reading of 55-60 volts AC.
- Connecting neutral to hot resulted in 120v.
So, is this safe to connect to the Quattro as is?
Alexandra avatar image
Alexandra answered ·
@Pau Hana
No. You have a floating neutral. The ground relay will `possibly fry in the inverter.
They are not safe in general to use.
pau-hana answered ·
Thank you- what is the solution for the floating neutral?
