cottersay avatar image
cottersay asked
Victron SmartBMV battery monitor keeps resetting to 100%!
I have read other responses to the problem of the Victron SmartBMV 712 battery monitor resetting to 100% SOC, even when the battery is almost discharged, but the answers did not solve my problem...
When my two 100Ah Battle Born batteries in my RV reach 30% SOC, I charge them up with my 2000W generator. However, when I begin the charge, the BMV 712 immediately reads 100% SOC on my phone. Why? Shouldn’t it start counting up from 30% SOC to 100% SOC as the charge cycle progresses??
Thank you!
FYI: After a full charge I have tried setting the “State-of-Charge” to 100%, as well as “Synchronize SOC to 100%”, and tried both on and off for the “Battery Starts Synchronized.” No joy.
BMV Battery Monitor
It would be helpful if you share your BMV settings..........
cottersay answered ·
Certainly! Here are my BMV 712 settings:
  1. Battery capacity: 200 Ah
  2. Charged voltage: 14.2 volts
  3. Discharge Floor: 0%
  4. Tail Current: 4.0%
  5. Charged detection time: 8 minutes
  6. Peukert Exponent: 1.05
  7. Charge efficiency factor: 99%
  8. Current threshold: 0.10 amps
  9. Time to go average: 3 minutes
