michael-weigand avatar image
michael-weigand asked
MPPT Solar charge controller with flexible panels and 24v
I recently bought four flexible solar panels. Their specification is as follow.
Maximum power(Pmax) 150W
Output tolerance ± 3%
Maximum system voltage 700V DC
Open circuit voltage(Voc) 21.6V
Maximum power voltage(Vmp) 18V
Cell efficiency 19.5%
Operating temperature(NOCT) 45±2℃
Temperature range -40℃~+80℃
Number of cells 36pcs
Weight 2200g
Size 1170*540*3 mm
So this is a total of 600W. I want to charge a 24v lithium battery with it. Can you suggest, how to wire and what Victron MPPT controller would fit best?
Thanks in advance,
Michael
MPPT ControllersMPPT SmartSolar
wkirby avatar image
wkirby answered ·
A 100/30 MPPT would cover 600W of PV on a 24V battery system.
2 PV modules in series and then 2 in parallel would be a good configuration if shading is a problem.
If shading is not a concern then you could wire them all in series, but make sure the ambient temperature does not get too cold otherwise there is a risk of going over the 100V limit on the PV side.
