I currently have a BlueSolar 150/70 connected to my MultiPlus II GX 3000/35 via VE.Direct. Can I parallel another BlueSolar that will be connected to the Multi via VE.direct/USB?
Hi, As the GX has 2 VE Direct inputs, I don't see that this should cause any problem.
Had to double check... but unfortunately the MultiPlus II GX 3000/35 has only VE.Direct port. but has 2 VE.Bus and 2 VE.Can.
Can I use a VE.Direct to VE.CAN interface (cable) to connect a second BlueSolar charge controller to connect to my Multi?
And you cannot use your CANbus connection on the GX for this. as stated in the datasheet.
use a usb-ve.direct cable.
Is it okay not to connect the 2nd MPPT charge controller to my MultiPlus II GX since all possible connection are already in use? I will just make sure that the charging settings / parameter are same with the Multi GX and my other charge controller (BlueSolar 150/70).
Thanks!
52 People are following this question.
