az3 avatar image
az3 asked
How many US3000 can I connect with three or four Victron Quattro 15kVA in parallel?
I need a capacity of 13.500 Ah for an off-grid PV system. I want to use the US3000 Pylontech and the Victron Quattro 15kVA. How many US3000 Pylontech can I connect with 4 parallel connected Victron Quattro 15 kVA? And how many with 3 parallel connected Victron Quattro 15 kVA?
az3 avatar image az3 commented ·
And what is maximum number of US3000 batteries for one Victron Quattro 15kVA?
Is 13.500Ah a typo? That would be 648kWh.
The maximum system size of Pylontech can be found in the manual (5x8).
The minimum recommended can be found here (around 8 modules for one 15kVA Quattro):
https://www.victronenergy.com/live/battery_compatibility:pylontech_phantom
az3 avatar image
az3 answered ·
Thank youI
And what is the maximum possible number of US3000 connected with one 15kVA Quattro?
There is no maximum for the Quattro.
For the Quattro it doesn't matter what battery or how many of them are connected.
But you have a maximum system size from Pylontech (5x8 modules connected to a LV Hub -> 40 modules -> 2.900Ah).
