dmay avatar image
dmay asked
AH setting
I just installed my BMV -712 smart. I have 4 - 6v in series with 235 AH in each. I set the unit to 470 AH and it took it but on the main readout it is reading 240 AH only. I tried to reset but it still shows 240. Doesn't seem right!
BMV Battery Monitor
Kevin Windrem avatar image Kevin Windrem commented ·
470 seems correct for 2s2p configuration.
What are you calling "main readout"? And where are you setting the value?
Stefanie avatar image
Stefanie answered ·
Hi @Dmay,
4x 6V/235Ah in series = 24V/235Ah
If you put them all in parallel, you'll get 6V/940Ah (Thanks for doing the correct math, Mark)
If you put them in series/parallel (2s2p), you'll get 12V/470Ah.
Mark avatar image Mark ♦♦ commented ·
4x235Ah in parallel is 940Ah, not 470Ah :-)
Not that you would actually wire it that way, as it's only 6V...
Stefanie avatar image Stefanie ♦♦ Mark ♦♦ commented ·
As a matter of fact: i was the worst in math at school :D
dmay avatar image
dmay answered ·
Yes they are series/parallel.
