hans-lenman avatar image
hans-lenman asked
Multiplus Compact 24/2000/50-30 / Firmware for new & older
I´m setting upp 2 pcs of Multiplus Compact 24/2000/50-30 for parallel operation. They don´t have identical firmware.
Victron Connect does not support the older one so I have to use VEFlash. Using an MK3.
Firmware older 2618152.
Firmware new 2618430.
Assuming I can update to identical version of firmware for both?
Which firmware is feasable?
Got a little confused when checking on firmware versions.
Thanks in advance.
/ Hans
firmware update
wkirby avatar image
wkirby answered ·
You can bring those to the same firmware level. 2618482 is the latest for both units.
hans-lenman answered ·
Thanks for your quick advice.
/ Hans
durval avatar image
durval answered ·
@Hans Lenman how is 2618482 working out for you? Did the upgrade proceed OK? Asking because I'm about to update mine.
hans-lenman avatar image hans-lenman commented ·
It worked just fine. Did not find ....482 but assumed 2618485 to be the latest version and used that.
durval avatar image durval hans-lenman commented ·
Thanks for reporting back, @Hans Lenman. For the record, I was able to upgrade mine to xxxx485 too (2608485 in the case of mine's model) and everything seems to be working OK. In my case, VEFlash did not work (kept throwing "connection error") but I was able to proceed using VictronConnect.
