anton555 avatar image
anton555 asked
Victron stopping voltage
I have my pv+ going through a fuse and my negative. When my wire isnt connected to my charge controller there is 62v aw the wire. As soon as I connect it to the charge controller and I measure the voltage at the wire its 1.3 volts. What's up with that? Every connection is fine until I connect it to the victron. Is the victron bad?
battery charging
Kevin Windrem avatar image
Kevin Windrem answered ·
Might you have the PV positive and negative reversed at the input to the charge controller?
