samuil avatar image
samuil asked
75/10 vs 75/15, which should I choose - for my set up?
Hi there,
I am deciding on whether to buy the 75/15 Bluesolar MPPT vs the 75/10 Bluesolar MPPT.
I will be using the VICTRON 12V 115W POLY SOLAR PANEL with the VICTRON 12V 110AH DEEP CYCLE AGM. Does the 75/15 vs 75/10 have any effect on the size of the load I can use?
I think it doesn't matter and the 75/10 is more than enough but just need some advice. None of the load is using more than 9 amps.
Thanks
Samuil
MPPT Controllers
seb71 avatar image
seb71 answered ·
Neither. Get a SmartSolar MPPT (75/10 or 75/15, depending on your local prices).
samuil avatar image samuil commented ·
If I were to choose smartsolar MPPT, what size would be adequate for my battery/panel?
The 75/15 or the 75/10?
seb71 avatar image seb71 samuil commented ·
SmartSolar 75/10 is big enough for a single 115W panel used with a 12V battery, but if the price difference to a 75/15 is not that much, get that instead.
