bobastrat avatar image
bobastrat asked
Bmv 712 setup for Chins 300ah question
For the battery most specs I could find is below:
Chins 300ah LiFePO4:
Rated Capacity (0.2C): 300Ah / 3840Wh
Cycle life: 2000+ cycles at 80% discharge depth
Rated voltage: 12.8V
Charge voltage: 14.2 - 14.6V
Depth of Discharge (DoD): 100%
Standard charge current: 60A
Charging time: Approximately 6 hours
Max continuous charge current: 100A
Max continuous discharge current: 200A
Peak discharge current: 600A (Duration: less than 3 seconds)
Operating temperatures: Charge 0°C~50°C(32°F~122°F),
Discharge -20°C~60°C(-4°F~140°F), Storage -20°C~50°C(-4°F~122°F)
Impedance: ≤ 15mΩ
My question is in the Victron connect settings for the bmv712 what should the following be for best results:
Under battery settings:
charged voltage:?
discharge floor:?
Tail current:?
charge efficiency factor:?
Under relay settings:
relay mode:?
invert relay:?
min close time:?
relay off delay:?
low soc relay: ?% ?%
low voltage relay:?
high voltage relay:?
BMV Battery Monitor
