System runs fine during the day when solar panels are getting sun. Voltage maintained at around 23.2 volts when under load running fridge and 12K mini split. When the sun goes down the system voltage drops and system shuts off.
Can't figure out what I may be missing in system settings.
System specs:
8 x 400 watt solar panels, wired in series and parallel.
2 x Victron SmartSolar MPPT Tr 150v / 60 amp
Victron Energy Lynx Distrbutor
Victron Multiplus 3000VA 24-Volt
6 x 100 amp hour Battleborn batteries wired to 24 Volt configuration
