col avatar image
col asked
Victron IP22 ABS parameters with LI-ION battery.
I hae just purchased a Bluesmart IP22 charger. I have a lithium 120AH battery. The charger is 30A, however when I put it on charge at 69% it goes to ABS and only puts in about 18A. would have thought that a lithium battery wouldn't go into ABS until considerably higher charge. I have set the mode to LI-ION , which has its own algerithum, can anyone tell me if I am able to raise the charge rate or make it so that it doesn't go into ABS mode until the battery is in a higher state of charge. Thanks. Col.
victron
Juan Alberto Félix avatar image
Juan Alberto Félix answered ·
Please, place this question into the general channel, this is only for questions in Spanish.
Anyway, maybe this can be due to the temperature derating (maybe).
