dannen avatar image
dannen asked
Raspberrypower consumption
Hi!
Does anyone know the rough power consumption of a Raspberry Pi 3B+ running Venus OS?
And is it possible to disable for exampel: HDMI or Bluetooth or downclock to lower the power draw?
Also, if using mobile wifi hotspot on iPhone, Will Venus OS automatically reconnect after loosing connection?
Raspberry Pi
Kevin Windrem avatar image
Kevin Windrem answered ·
I measured my RPI 4 with the official 7" touchscreen running Venus OS at about 3 watts (screen blanked). I measured about an additional 2 watts for two VE.Direct USB adapters, one MK3 USB adapter and a CANable USB CAN-bus adapter.
The RPI 3B+ should be less but don't know by how much.
trygvelu avatar image
trygvelu answered ·
The information here gives a clue: https://www.raspberrypi.org/documentation/hardware/raspberrypi/power/README.md
The numbers are at 5.1V, so for the 3B+ (bareboard typical): 500mA * 5.1V = 2,55 watt
For RPi4 600mA => ~3W
On my boat I run multiplus (idle), smartsolar (idle), RPi 2 with DSI screen, CAN board, ADC board with tank interface, GPS, MK3 USB adapter, VE Direct USB adapter and a 4G router, and combined consumption is ~12W (0.9A @13.3V).
ghostrider avatar image
ghostrider answered ·
With 2 VE.Direct USB adapters, GPS & WiFi on..I draw about 15w.
And yes, when disconnected, data is stored locally and then it is all uploaded when a saved wifi connection is restored.
Elimac avatar image
Elimac answered ·
I have a small test bed running one RPi 3B with 2 USB connected Lithium BMSs and one USB/VE.direct connected 100/20 MPPT. I see power consumption between 2.5W and 3W on the output of the 5V DC/DC converter that powers it.
pulquero avatar image
pulquero answered ·
On my setup, RPi 3B+ with 1 USB VE.direct and WiFi consumes about 2W. I wrote a node-RED flow to reduce VRM logging frequency when the MPPT controller is off to try to save some more power.
pulquero answered ·
I've managed to further reduce power consumption by having a node-RED flow that turns wifi on/off overnight using 'connmanctl enable/disable wifi'. This can be a bit annoying when wanting to work on the pi 'outside hours', so I have further written a BLE GATT server that allows me to also toggle wifi on/off via bluetooth.
nick-a avatar image
nick-a answered ·
My pi zero 2W uses about 1.5W with 3 usb dongels attached + wifi.
pulquero answered ·
I found that turning the usb bus off (writing 0 to /sys/devices/platform/soc/3f980000.usb/buspower) reduces the power consumption to around 1W. This can be used to save power overnight.
