I'm trying to add a python module (or more to Venus OS. There is no pip installed and when I try to use apt-get to install pip that isn't there either!!.
When is Venus OS going to move to python 3.x?
Hi Mike, please understand that Venus OS is not a full blown desktop or server oriented Linux distribution. Instead, its an embedded version, with all the advantages as well as limitations that come with that.
there is no apt-get, but there is opkg. And there is no dir, but there is ls.
For more information, study this:
https://www.victronenergy.com/live/open_source:ccgx:commandline
and this:
https://github.com/victronenergy/venus/wiki/commandline-introduction
And this:
https://github.com/victronenergy/venus/wiki/installing-additional-python-modules (could be outdated!)
And while at it, study the rest of the pages on the venus github wiki as well.
Python3 move is in progress, there is an issue open for it, you can keep an eye on that as well as meta-victronenergy to see progress.
enjoy the day, Matthijs
You can install pip
curl https://bootstrap.pypa.io/pip/2.7/get-pip.py -o get-pip.py
and then
python get-pip.py
File "get-pip.py", line 82, in bootstrap
from pip._internal.cli.main import main as pip_entry_point
File "/tmp/tmphUUG4i/pip.zip/pip/_internal/cli/main.py", line 10, in <module>
File "/tmp/tmphUUG4i/pip.zip/pip/_internal/cli/autocompletion.py", line 9, in <module>
File "/tmp/tmphUUG4i/pip.zip/pip/_internal/cli/main_parser.py", line 7, in <module>
File "/tmp/tmphUUG4i/pip.zip/pip/_internal/cli/cmdoptions.py", line 25, in <module>
File "/tmp/tmphUUG4i/pip.zip/pip/_internal/cli/progress_bars.py", line 12, in <module>
File "/tmp/tmphUUG4i/pip.zip/pip/_internal/utils/logging.py", line 18, in <module>
File "/tmp/tmphUUG4i/pip.zip/pip/_internal/utils/misc.py", line 9, in <module>
ImportError: No module named getpass
????? First command worked fine, second gave the above error?
Thanks Guys,
I only started looking into this development a few days ago, and I'm still finding my feet in this. I did also realise that the module I need to install is a slightly customised version, so has to be 'built' in place. I do have the code to do this -
Re the python 3 upgrade, this will cause a major rewrite to some applications as for one instance in python 2.7 the return statement does not need parenthesis whereas in python 3 they are mandatory.
I'm trying to migrate my bms software which runs on the Pi to the Venus OS.
I upgraded Venus to latest 2.72~4 and now have pip - but some other errors still. Still, a lot more working, and there appears to be a version of gcc which was the root cause of the problem trying to build the spi module.
I'm on v3.00~15 trying to install pip and get error "ModuleNotFoundError: No module named 'colorsys'" when running "python3 -m ensurepip". The pip version is "pip-22.0.4", python is Python 3.8.13.
My assumption is that this is not pip install issue but rather a missing module in python3 on VenusOS. Am I right?
Currently switched to Beaglebone black due to lack of pi's.
With a clean VenusOS-System pip3 could be installed like this.
~# opkg update ~# opkg list | grep pip ~# opkg install python3-pip
and with VenusOS-Lange-v3.00~14 - pip Version 20.0.2-r0 gets installed.
If this:
~# python3 -m pip3 install --upgrade pip3
or this:
~# python3 -m pip install --upgrade pip3
is execute - pip doesn’t work anymore.
With this command:
~# opkg remove python3-pip
you could remove pip and restart the pip-installation if you need pip3 again.
Version-Check:
~# python3 --version Python 3.8.13 ~# python -m pip --version pip 20.0.2 from /usr/lib/python3.8/site-packages/pip (python 3.8) ~# cat /opt/victronenergy/version v3.00~14 Victron Energy 20221221202311
46 People are following this question.
