denzel avatar image
denzel asked
Firmware update 2610 Multi (Latest) - Findings
Hi Guys,
My setup :
Multi 24/3000/70 old spec Inverter
150/70 MPPT
24v Led Acid batteries .
Configured to send excess power to the grid if batteries and loads are catered for.
On Saturday i performed an upgrade 2610 via the victron GUI. I followed the steps as defined and heres what happened :
After the upgrade i was given a default configure file which i had to convert to .vff .
I had to redo all my settings as they were however they dont function like that anymore. I ended up my batteries only getting to 74% SOC and the solar is almost on an on demand status. I see myself using power from the grid as primary. Im using a "Self-consumption Hub-1" .
Im now performing an equalization to see if the things normalize .
Has anyone else had any anomalies with this update ?
firmware update
denzel avatar image
denzel answered ·
Update to my post: an equalization has restored my inverter to correct operation .
