kevinvh avatar image
kevinvh asked
BUG REPORT: CCGX Firmware V2.71
There is a bug in the CCGX firmware V2.71.
After updating to V2.71, my CCGX stopped recognising my MicroSD card as external storage under VictronConnect/Settings/VRM Online Portal/MicroSD/Usb - it showed "No storage found".
I tried two seperate MicroSD cards (both previously worked) - both not recognised by CCGX. Tried reformatting both MicroSD cards (16GB and 32GB Fat32) - not recognised by CCGX. Inserted a 16GB Fat 32 USB stick in the CCGX USB port - it WAS recognised by VictronConnect/Settings/VRM Online Portal/MicroSD/Usb as external storage.
I rolled back to the CCGX firmware V2.66 and both my MicroSD cards now work with VictronConnect/Settings/VRM Online Portal/MicroSD/Usb.
Can Victron please fix the bug in firmware V2.71 please.
firmware update
Kevin Windrem avatar image
Kevin Windrem answered ·
I can confirm that a CCGX running v2.71 (or v2.72~2) does not recognize an SD card for VRM backup. The same is true for off-line software updates including at boot.
There is noting in /media on the CCGX with the SD card inserted.
Cerbo running v2.72~2 does recognize the SD card and uses it for VRM backup.
/media shows mmcblk0p1 when the SD card is inserted on Cerbo.
I used the same SanDisk Ultra 64 GB SD card formatted FAT 32 in both devices.
digimer avatar image
digimer answered ·
I'm having the same issue; V2.72, Sandisk Extreme 128G. It says "no media found", but it works OK in my camera and laptop.
Kevin Windrem avatar image Kevin Windrem commented ·
Current on-line documentation says that the card must be a max of 32 GB. That said, I was able to use a 64 GB card formatted FAT 32. It may be that a 128 GB card can't be formatted FAT 32 which might explain the problem.
For grins, try a smaller card.
bezda avatar image
bezda answered ·
Same here, firmware 2.73 - I've had 32G card in for over a year, suddenly after a last update it stopped working. Cerbo wouldn't even connect to VRM portal and send data, very difficult to find root cause. Card removed now and evreything is fine
