Did you update the Victron Connect firmware just beofre this started? The most recent firmawre update has a bug in it that couses this type of behavior. Victron is working on a fix and I am told it will be out soon.
The firmware update is certainly causing your problem. The lesson here, for me at least, is never update my Victron Connect App for at least two months when a new update comes out. Two months will give Victron time to fix any bugs in the firmware releases. The Victron Connect App contains copies of all firmware for every Victron device. It was updating the Victron Connect App on my iphone that forced a mandatoiry update of the firmware on both the dongle and my multiplus. In this case I am not certain which firmware is actually cauring the problem, the smart dongle firmware or the multiplus firmware? I asked Victron but got a vague answer about it being both.
You may be able to get your Multiplus working 100% again if you have Ve Configure on a laptop. Watch this video for details how to do this.
30 People are following this question.
