ankimo1978 avatar image
ankimo1978 asked
MultiPlus Compact is showing a different loading state than it is using
I have a small RV electricity setup including a MultiPlusCompact 12/2000-80, two solar charger MPPT 100/50 and 30 currently without solar panels (waiting for the right weather to mount them on the roof) and a Smart TR-Orion B2B Loader. The MultiPlus is connected to the Bluetooth smart dongle.
My setup is equipped with a LiFePO4 battery from Offgridtec. Due to the space I have available I was not able to use a Victron Battery. The are simply too high for my double floor.
I did a software update of all devices and since then the MultiPlus did not load the battery. The app simply showed Failure (Störung in German). I stopped and started the MultiPlus and now it charges the battery with 50 Amps. Which is correct as the battery was only 80% charged, but it shows the Status Storage in the App and a Loading current of 0 Amps. If I look into the BMV and the BMS of the Offgridtec battery both show the 50 Amps charging current. So the MultiPlus State is clearly wrong displayed. Any suggestions what to do?
Thank you for your support
Kind regards
The pictures are all taken at more or less the same time.
battery charging
ankimo1978 answered ·
I just want to add that the MultiPlus App is showing no AC In, but it is showing Storage which only could happen when an AC In is there. During the Screenshot AC In was connected and used to load the battery.
