I am looking for the firmware for the new Multiplus II 2X120 volt. I can't find it on Victron Professional. It doesn't seem to be listed in the VE.Bus firmware numbers.txt file. What is the family number?
Do you already have the Multi?
If yes you could just use VictronConnect to update the firmware. VictronConnect will automatically select the correct firmware.
Or you use VE.config to connect to the Multi and than you can select "target" -> "show software version"
32 People are following this question.
