I would like to know if Victron Smartsolar Mppt, in my case a 100/50 model, come set at their full working capacity or does it have to be set?
These come with some default battery parameters, but the current is set to the unit max (50A). You can customise the battery voltage settings, times and capacity with Victron connect or with VE Direct controller.
Thanks for your explanation. Input wise, better said, voltage wise, it is set to 100 volts, its full capacity?
50 People are following this question.
