BMV 712 smart 2 6 volt battery
I have mid range selected in the software. however the digital display does show mid range for voltage correctly but the app only shows mid percent deviation. Is there anyway to view mid range voltage through the app?
Temporarily changing to auxillary with get you a mid point voltage in the app, but then of course you lose the alarms and control over mid point deviation. This would probably make for a good feature request, since I'm not aware of any other work arounds.
Attaching a cerbo GX or equivalent gives you more granular information remotely, but is an expensive way of doing it...
33 People are following this question.
