davydoram avatar image
davydoram asked
Quattro Relay function - when no active ac input query
Greetings,
Wondering if there is a way in Quattro Assistants setup, to drive a relay trigger where if neither ac-input source is present (basically inverter) mode - the unit triggers a relay output.
Id like to use no active AC Source, or the unit switching into invert mode, to relay switch some secondary non-inverter loads.
The setup is using a 230V quattro where neither source has a neutral and the AT afterwards makes it back up. So AC-Output 2 is not an automatic option because the neutral is not in the system yet for switching the ac loads, like it is after at the main panel.
