What sort of generator do you have? Does it have remote start and how is it meant to be wired?
The multiplus has relay outputs that can be configured in VE.configure with a mk.3 device or a GX device.
Unfortunately there are multiple ways this can work, so to give you a simple answer will need more information first.
Hi @Pat
There's an overview here.. https://www.victronenergy.com/media/pg/Automatic_Generator_start-stop/en/which-relay-and-control-to-use-.html
Depends what other kit you might have, and running a generator until batts are "full" needs some consideration too to get best value from your fuel.
You may have more to tell us if you want more detail and experiences of others.
GX - Generator auto start/stop
29 People are following this question.
