Joka GIMENEZ avatar image
Joka GIMENEZ asked
Best setup for spread battery bank on boat (10m apart) - multiple mppt
Hi!
The batteries on my boat are quite far apart (1 battery - 4m - 2 batteries - 6m - 1 battery).
I'm wondering how to best and evenly charge all batteries to get the longest life out of them.
Due to my panels setup, I am planning on using 3x SmartSolar mppts synchronized with Bluetooth : 2x 75/15 and a third one, ideally 100/20 but could be 75/15 too.
I guess the ideal setup would be to have the 3 panels side by side to a charging bus, then equal distances to each batteries, but it will require quite some cable length!
I was wondering if having 1x 75/15 near each single battery and the 100/20 near the 2x batteries would still be efficient, or if the uneven charge would trigger the absorption cycle too early?
Thanks for your input.
MPPT Controllers
tozz avatar image
tozz answered ·
You need to route the positive cable to/from your charger/inverter to one side, and the negative cable to the other side. So it would become something like this in series:
[+] - [batt1] -4m- [batt2] - [batt3] - [-]
Or in parallel:
| - [batt1] - \
| - [batt2] - |
\ - [batt3] - |
Where [+] is your positive lead and [-] is your negative lead to your inverter/charger
Do *NOT* do this:
| - [batt1] - |
| - [batt2] - |
\ - [batt3] - /
If you do this last diagram, batt1 will do most of the work, and degrade much faster than batt3.
Joka GIMENEZ avatar image Joka GIMENEZ commented ·
Thanks, excellent tip!
Is it important that the positive and negative terminals have the same length? Or can I eventually go with 30cm to positive and 5m to negative?
Cheers!
