jk0te avatar image
jk0te asked
Multipass 24/3000 AC Connection
A. The MP 3000/24V has two (2) AC outputs and one (1) AC input. If the unit is off, will it still allow the input AC to go out either of the (2) AC outputs?
B. There are two AC outputs. For a 30A 110V system, is it necessary to use both AC outputs to get the full 30A service? (Assuming the wire gauge connected to the output is sized properly to carry at least 30A)?
C. Is it better to connect AC to the unit and then program or can it run on DC battery input for programming or both?
Multiplus-II
