I don't have a VE config at the moment. Which settings can I best use for my 2x100Ah 24V LiFiPo4 bank? How important is it to buy a VE connector?
Hello.
I would strongly recommend to do the configuration with VE.Configure. The MK3 is very cheap compared to the batteries you purchased. When you add the VE.Bus BMS assistant to Multi, you will see the below settings.
As it is seen, there is not a matching characteristics with dip switches. Also, absorption time should be 1 hour.
I hope it helps.
43 People are following this question.
