northernboy avatar image
northernboy asked
Grid and new Generator have different Phase Sequence, how to correct?
My 3 Phase Grid sequence is (According to the grid meter on the color controller) L1-L3-L2
I just connected my new generator and with the....
Multiplus's switched to "on" Inverter lights on constant. No Battery Charging.
Multiplus's switched to "charger only" main lights flash on line 1,2, main and float lights flash on line 3, No Battery Charging.
I then checked my 3 phase Generator sequence and (According to the grid meter on the color controller) it's L1-L2-L3
What is the best way to fix this issue, I guess the system is set up for L1-L3-L2 as it all works fine when the grid is connected.
Generator
harold avatar image harold commented ·
Just can switch 2 connections of the generator, i suppose???
northernboy avatar image northernboy harold commented ·
I did wonder if I could just switch L2 and L3 on the Genset plug wiring but thought I would ask first.
northernboy answered ·
I am answering my own question in case someone has the same issue. I switched L2 and L3 over on Genset, now Genset and Grid have same phase sequence. Everything now works OK.
ted avatar image
ted answered ·
I have the same problem. So you did only switch the L2 and L3 at the IN and OUT Port from the EM24, or?
12 comments
wkirby avatar image wkirby ♦♦ commented ·
As he says above, he switched L2 and L3 on the generator.
marekp avatar image marekp commented ·
@Ted
Switch L2 & L3 only at the EM24 input.
ted avatar image ted marekp commented ·
I have a 3 phase Multiplus System. Think, if I only change the EM24 Input Port, then a phase rotation error would appear in the MP System, since you set each Multiplus to a specific phase in the VE Configurator
marekp avatar image marekp ted commented ·
@Ted
The error you see is caused by the difference in phase rotation between incoming AC and your Multiplus system.
You have 2 options.
1. change phase rotation on the input of your system (EM24).
2. change phase rotation of your Multiplus system.
First option is simpler and does not require changing phase rotation on all your 3 phase loads.
"The error you see is caused by the difference in phase rotation between incoming AC and your Multiplus system. "
To clarify. The L1-L3-L2 Phase sequence in the Cerbo EM24 overview currently throws NO phase rotation Exception in the MP system at all. With an additional 3-phase generator at the AC-In, it is another thing.
I can of course change L3-L2 already at the output of the main switch for the AC-IN of the MP System. But still not sure, that I then need not reconfigure the MP-2 and MP-3 with the configurator since they get another phase. But the MP has each a phase detection, like the EM24. So, is it possible that the EM24 "rewires" the L3-L2 already?
@Ted
Change the EM24 input AC phase rotation and see what happens. :)
I did test it. Turned off the AC-IN main Switch, while the MP System switched to battery-only mode. Then rewired L3-L2 and turned on the AC-IN main Switch. Not even a relais test started ...
Result:
After i did unchange it, the relais test worked fine.
@Ted
Can you try to change L2 & L3 on the output of the EM24?
Without any further connection to the MPs, you see already in the EM24 Menu the phase order of the 3 Phases, so L1-L3-L2 are at the EM24 Display. So to "fix" this, I think it is needed to rewire L3-L2 at the EM24 input Port and then reconfigure the L3 and L2 Multiplus via the ve configurator
@Ted
Changing phase rotation at the input of EM24 and at the MP-II will not fix it.
Change needs to be done only in one place.
Before you do the reconfiguration of MP-II, change L2 and L3 at the EM24 output.
I had 2 systems with this L1-L3-L2 in the grid meter menu.
One would not connect to grid with the "Wrong phase rotation detected" massage. Change L2 and L3 on the EM24 AC input fixed the problem.
Second one worked but system had problem with balancing phases. Change L2 and L3 on the AC out of EM24 fixed it.
Switch L3/L2 at input and output (EM24) should work. The 3 fields remains, but the "measuring channel" is exchanged only. Will test it and tell you
I changed today IN and Out Port at the EM24 to switch L1-L3-L2 to L1-L2-L3. Worked fine without error.
