Looking for a quick review on this schematic, though not sure if this is the right place for it. Can someone experienced give me some feedback? Thanks in advance.
@rep.adventures Did you ever build this. Any issues? The only change I would make is probably to connect all of the appliances to the "load" connectors on the solar charge controller. That way you can monitor your output via the solar blue tooth app.
26 People are following this question.
