Hi - I'm running the 150/70 with 6 panels (320W). Two strings of 3 panels - connected in a combined bow before plugging into the MPPT. I'm only getting 110V and 0.3 AMPS ? Also only getting up to 40W off the solar array. Anyone have a suggestion ?
Running 8 of these in two 4 battery series
How have you programmed the mppt? voltages battery type etc.
The batteries are only taking 1A in. The other possibility is they don't need a charge?
is currently running setting #2 on ratoary dial - AGM batteries
The little red exclamation on the cog at the top right means skmething needs attention there. Possibly an update. It may be best to run that as a troubleshooting step
Then follow this video to set up for your batteries
26 People are following this question.
