wmbriancox avatar image
wmbriancox asked
The Password to change setting in VictronConnect
I recently installed the Victron 12/3000/120 Multiplus. When I installed this, I was using lead acid batteries. Now I want to upgrade to Lithium Ion batteries and know that I need to change the battery settings internally. I have a MK3-USB ordered but also see that I'll still need a password to use this to get access and make these changes. Everything here says to "contact my dealer." That's what I don't want to do.
My dealer, has been extremely hard to work with. When I installed the unit, I had questions that I'd asks and their responses were horrible. They don't really talk in person, so I get emails from them that usually take several days and then don't answer my questions. I was reading the manual and wanted to ask several questions about the use of the dip switches to customize/optimize settings. their response, "Those are factory settings, don't touch the dip-switches." There was no discussion, only this response. I've read the manual and I've read forums now and found that there are valid reasons to set up the dip-switches. Anyway, I'm very dissatisfied with my dealer, but need the password. I've seen one person on here state that there is a default code of 000000. I don't know if that is correct, but when I change the batteries out I will need tis code and as this is basically the initial startup for this unit, I'd also like to do the firmware update as recommended. I've already downloaded the app onto our Windows computer, and I am awaiting the arrival of the MK3-USB and batteries. Can someone give me a point of contact to get this password besides the dealer?
Multiplus-II
The password is in the VictronConnect - VE.Bus Configuration guide just search for "password"
https://www.victronenergy.com/media/pg/VE.Bus_Configuration_Guide/en/index-en.html
Or you use VE.config instead of VictronConnect there is no password needed.
wmbriancox avatar image wmbriancox commented ·
I searched and all I that came up was a short video showing a hidden password being typed in and being directed to check with the supplier for the password again. Did I miss something?
wmbriancox avatar image wmbriancox Matthias Lange - DE ♦ commented ·
Got it! Thank You. I don't know if I overlooked that or what the first time, but I appreciate the help. Thanks again.
dennisdordt avatar image
dennisdordt answered ·
Same question, but the above mentioned link is no longer working. Anyone who can help me out?
jana avatar image jana commented ·
I have the same question. Please someone help!
regman54 avatar image regman54 jana commented ·
The same question as what? Could you please be more specific. It helps everyone if you do. Thanks.
Matthias Lange - DE avatar image Matthias Lange - DE ♦ jana commented ·
It's still the same manual using Google or looking at the Victron website would bring you there...
https://www.victronenergy.com/media/pg/VictronConnect_configuration_guide_for_VE.Bus_products/en/firmware-updates.html
