jamesharris avatar image
jamesharris asked
State of charge time remaining - Infinite error
I accidentally ran my solar-charged battery flat (I have a Easy Solar 1600VA Inverter). The app says that the recharge time is 'infinite'. Does mean my battery is dead forever?screenshot-2021-06-06-at-132623.png
battery charging
"Time remaining" is not for charging it is only discharging.
It shows infinite as long as you have a positive current going into the battery.
Just recharge the battery and you should be fine.
jamesharris avatar image jamesharris commented ·
Thank you Matthias!
One quick follow question though - the 'state of charge' is still reading as 0%, even though I have been charging now for over 8 hours. I've left my inverter switched off while it charges up - could that be why it's not able to update this charge state percentage or could this indicate that it's actually not holding any charge?screenshot-2021-06-06-at-161053.png
Matthias Lange - DE avatar image Matthias Lange - DE ♦ jamesharris commented ·
What battery capacity did you set in the settings and what battery capacity do you have?
