I am currently running 2.66. When I attempt to check for the latest release candidate I get the message "Error during checking"
Hi thats right; at the moment there is no release candidate to check. See pinned post on v2.70~16 on modifications.
try again tomorrow
@Duncan Hall I was new to all of this as of yesterday. Like you, I wanted to try the latest and greatest and found that you have to wipe the 2.66 build completely and be running something past 2.70~4 to have online and SD upgrades made possible. I'm now running 2.70~19. This is how I did that if you don't mind starting again.
As I'm a NOOB, treat my advice with caution but this is what I did in order to test the latest features.
While @mvader (Victron Energy) answer was also true, that was just a temporarily issue, so I changed the accepted answer to this one, you can't automatically update a rpi3 from 2.66 to 2.7x, since new firmware blobs are needed, which aren't deployed automatically, since it will make the rpi unbootable during the process. So it is a manual step, on purpose.
Second thought, lets accept both answers:
- Error during checking occurred temporarily with v2.66 since the update feed was unavailable
- No update available should be shown on v2.66 since it requires re-flashing first.
Strange that I have the same on my Raspi3b+ with 2.66 if it checks for the new regular 2.71 firmware...
so what is the way to update the firmware on the raspi? can i do it via ssh?
35 People are following this question.
