Dosheimer avatar image
Dosheimer asked
Node Red broken because of unwanted qml files update?
Hi all!
A few weeks ago my Node Red (VenusOS v2.70_3-large-12) suddenly was broken on my Raspi 4B (4GB). A lot of files has been updated, which i can't understand. I'm sure, that the automatic updates has been deaticivated. Also the /opt/victronenergy/version hasn't been changed.
For example one of the updated qml files:
--- 20210507/opt/victronenergy/gui/qml/PageTankSensor.qml
--- v2.70_3-large-12/opt/victronenergy/gui/qml/PageTankSensor.qml
@@ -18,7 +18,7 @@
MbOption { description: qsTr("Black water (sewage)"); value: 5 }
- property VBusItem devInstance: VBusItem { bind: Utils.path(bindPrefix, "/DeviceInstance") }
+ property VBusItem connection: VBusItem { bind: Utils.path(bindPrefix, "/Mgmt/Connection") }
property VBusItem customName: VBusItem { bind: Utils.path(bindPrefix, "/CustomName") }
property VBusItem fluidType: VBusItem { bind: Utils.path(bindPrefix, "/FluidType") }
property VBusItem volumeUnit: VBusItem { bind: "com.victronenergy.settings/Settings/System/VolumeUnit" }
@@ -30,7 +30,7 @@
if (customName.valid && customName.value !== "")
return customName.value
- var inputNumber = devInstance.valid ? devInstance.value : ""
+ var inputNumber = connection.valid ? connection.value.replace(/\D/g,'') : ""
var inputNumberStr = ""
if (inputNumber !== "")
Any idea, what happend there? I will shortly update to the latest version. Will this fix this problem?
Thanks!
Node-RED
