skykay avatar image
skykay asked
Strange behaviour multiplus II 48/5000
When the multi is not charging the batteries and I use a 3000w high pressure cleaner everthing is working fine. When the sun is shining and the multiplus is loading my batteries and I try to use the
high pressure cleaner the fuse of this circle pops out. The high pressure cleaner is part of the critical loads.
(the pic is just for overview - not an example of the case)
2 SmartSolar MPPT VE.Can 250/85 rev2
BMV-712 Smart
MultiPlus-II 48/5000/70-48
Cerbo GX
Multiplus-II
solarhack avatar image solarhack commented ·
I don't know the answer but have some thoughts.
I have a few questions:
  • What is the solar yield when this happens?
  • What is the battery consumption?
  • What is the grid load?
  • Is Power assist enabled?
  • Have you checked your earth and ensured you have no earth loops?
skykay avatar image
skykay answered ·
Solar yield is arround 3000-4000w
Batterie consumption max 500w
no grid load
power assit is enabled
installation was done by a prof. elec. so I assume that there are no loops
thanks
Sorry about the delay. I was exploring some ideas and got sidelined with work
