Is the the smart battery protect able to have the disconnect set high(~27)volts and the re-connect set low(~26.2) volts.
I would like to put it in front of an ac2dc charger to terminate/resume charging like a drinking bird.
Can someone please try to make a user defined profile with the disconnnect set higher than the re-connect?
If the user interface will allow it I would expect it should work.
Also any idea how much stress its going to put on the fets to switch ~20 amps at 24 volts nominal?
26 People are following this question.
