Brand new IP22 Charger.
Put into system replacing old charger. I am getting no amps. out. see image.
My battery is at 75Ah and is a 110ah Battery. I also have a load on motorhome off 7amps and when all on still no amps from IP22
Check the fuse at the bottom of the device, next to the connection terminals.
You need a multimeter now.
What voltage can you measure at the battery connection of the charger? Battery voltage or charger voltage?
If it is the battery voltage and the fuse of the charger is ok then there is an internal problem and you have to contact the dealer from whom you bought it.
If it is the charger voltage then the charger is ok and you have to go down the line and check all connections, fuses/breaker and/or switches between the charger and the battery. At some point the circuit is open.
Get this. Left the IP22 on me system overnight. Must have had a little chat to system and the battery and all is good :)
Image shows amperage been given with all my load on, such as fridge etc.
So hopefully happy days. :) Thanks to all and fingers crossed
26 People are following this question.
